How to change sample rate
Hi everyone,
I am using lab view to record resistance of my sample while applying cyclic load on it. On my lab view VI how can I change the sampling rate? right now is on 1 Hz and I need to increase it.
(2,365 Views)
Accepted by Niloofar93
You have 1000 ms wired to the wait function; that gives you 1 Hz sampling rate.
If you increase the sampling rate will your LCR meter be able to keep up?
mcduff
(2,352 Views)
Yes, I changed it to 200 ms and it is working well. Thank you.
(2,345 Views)
