How to change the background color of graph?
The graph default color is black ,I want to change it into white,how to do it? I searched in labview forum but there's no satisfying answer.Who can help me?
Labview 7.0
(37,430 Views)
You can create a property node and select Plot Area -> Colors -> BGColor.
You can then use the Color Box Constant located in the Numeric -> Additional Numeric Functions palette to set your background color.
Hope this helps.
(37,427 Views)
Doesn't sound as if you wanted to change the color programmatically.
Why don't you use the paint brush tool, in the tool palette ?
Chilly Charly    (aka CC)
(37,427 Views)
Thanks very much for your help!I've modified it using paint tools!!
(37,414 Views)
