How to derive signal
how I can derive signal described by attachment. It is linear sensor data in mm.
I have to derive it to get speed and velocity. Is it possible to get it to the chart?
Time between values is 1 ms. or it should be... 🙂
I am using labview 7.0
thank you.
(2,933 Views)
Check the annexed vi:
Hope it helps,
Paulo
(2,917 Views)
