Showing results forย
Search instead forย
Did you mean:ย
How to change the range on a graphic but saving the same points
Hi
I have a graphic with 501 points on X axis, and autoscale on Y, and then when i generate the graphic i see the X axis from 0 to 500.
But now i need to change the scale to see the X axis from 50 to 100....but all points need to be the same as 0 to 500.
I think what i need is just removing the strings 0 and 500 and replace by 50 to 100, without changing anythink on the graphic itself.
Is this possible on LabVIEW?
Notice that i'm not asking for a zoom on the graphic...there is no zoom, only the numbers of the X axis needs to be change after i generate
the graphic ๐Ÿ™‚
thanks!
(2,940 Views)
Accepted by topic author JPLO
Hi JPLO,
you can change the scale presentation by setting an offset of 50 and a scale multiplier of 0.1 either in the properties dialog or by using property node(s)!
(2,936 Views)
worked ๐Ÿ˜„ thanks! kudos for you ๐Ÿ˜‰
(2,921 Views)
