converting U8 image into RGB
I have a pixelink camera that when I run through the IMAQdx vi's, it produces a BW image.  When I view the image, I can select from the palette bar when I right click on the image out display and select rainbow, temperature, etc....but I can't save these colored images.  I'm guessing that the image out viewer converts the U8 image into a RGB image for display.  I would expect that there would of been a VI (or maybe there is and I haven't seen it) that would do this task and allow you to save the image as a RGB.  Is there a VI to do this?
guilio_2008
(9,114 Views)
There's a function in LV to convert color (U32) into RGB : "Color to RGB.vi"
You can find this VI in the function palette : Programming > Graphics & Sound > Picture Functions > Color to RGB.vi
Best,
J.
(9,108 Views)
guilio,
It sounds like you would like to save a bitmap of the image rendered in the control when viewing one of the mappings - temperature, rainbow, etc?
If you have access to the NI Vision Development module, you can use IMAQ GetPalett.vi to generate the R, G, and B lookup tables to remap pixel values to render temperature or rainbow.  You can then use IMAQ ReplaceColorPlane.vi to combine your R, G, & B planes into an RGB image, and IMAQ Write File 2.vi to write your file as a bitmap.
-cb
(9,089 Views)
The IMAQ UserLookup.vi will re-map pixel values.
(9,088 Views)
I tried doing just the pallette, but it doesn't change the image when I have on front panel.  I'm guessing you need to use the open image window to get this working?  Any examples?
guilio
(9,065 Views)
Do you have the NI Vision Development Module? If so, this sloppy little bit of code will let you change an image palette on the fly, then save out a copy of the color image you see. You can also choose a user defined palette and create your own palette with the color ramp next to the window.
-root
Message Edited by Root Canal on 05-05-2009 11:11 AM
global variables make robots angry
(9,042 Views)
