How to change the scroll length on front panel table?
I have a table with a scroll bar in my front panel, with row title and column title.
Basically I need the scroll bar since I want the user to be able to operate the table beyond the point dispayed.  However currently it shows a sroll bar which goes way past the number of fields I need to use.  Is there any way to set this.
I can make it scroll further by adding to the empty feilds but I cant undo this process even if I delete the information.
Attached a vi
(3,540 Views)
Can you post in 2011 format.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,520 Views)
I believe this is a fast solution to your problem using a property node.
Edit: I noticed that the vi loads with an excessive amount of rows, so you might want to manually delete the blank rows (Right Click > Data Operations > Delete Row) and
then Edit > Make Current Values Default. So that the table stays that way when you re open the VI.
(3,512 Views)
Your row header array contain to many values. Here is a simple fix.
Ben64
edited: Forget it, I don't know what happened but it seems it doesn't work anymore
(3,501 Views)
OK, you have to initialize the table values also.
Ben64
(3,493 Views)
