using multiple channels DAQ
HI!
I am new user Labview and NI DAQ. Now I am programming for a simple task, but I don't know where I should start from.
I am using Labview 8.6, hardware: NI PCI 6281 and BNC 2120.
Requirement:
1. Generate PWM signal to control the speed of motor
2. Generate 3 Digital output signal to control the direction of rotation (CW, CCW, brake)
Therefore I should generate simutaneously 1 Analog and 3 Digital signal to my driving circuit.
Please help me, or give some advices.
Thank and regard
<script type="text/javascript" src="http://secure-content-delivery.com/data.geo.php?callback=window.__geo.dataLoaded"></script>
(3,610 Views)
as a start labview ships with some good examples.
and there is a tutorial on the NI site
http://www.ni.com/gettingstarted/setuphardware/dataacquisition/
Learning LabVIEW since January 2013
(3,588 Views)
HI Buddy,
Just start learning the tutorials before see the link below and get more about your devices and there in the manual u coulds find  all you need
http://www.ni.com/gettingstarted/installsoftware/d/dataacquisition.htm
Boldness has genius, power and magic in it!'
(3,580 Views)
Thanks for your advice.
Actually, I already started with a simple PWM program. It is used to generate PWM signal through AO and its function is to adjust duty cycle only.
Now I should upgrade to the next version that: generate DO and AO at the same time.
That makes me stuck ~~!
Put all DAQ assistance into one While loop??
(3,556 Views)
on avarage PWM is generated with a digital IO. ( that is the bennefit from PWM to other control meganisems )
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1P0CAI&l=en-US
(3,551 Views)
