How to check 6 digital signals change value at the same time with PCI-6229??
I am using DAQ card PCI-6229.
Channel 1 generate a digital signal.
Channel 2,3,4,5,6,7 acquire digital signals.
I want to check:
1. Whether the rising edge of Channel 2,3,4,5,6,7 occures at the same time;
2. The time delay from the rising edge of Channel 1 to the rising edge of Channel 2,3,4,5,6,7 is within a certain range.
I know I can use counter to get the two edge seperation time delay. But I only have two counter, it is two time-consuming if I check one by one.
I don't know how to check the rising edge of 6 different channels occure at the same time.
Does anyone has any suggestions?
(2,479 Views)
You can use the DAQ card's digital input change detection circuitry to detect changes in the input, you can then use a counter to measure the relative time between samples. Please read Page 6-9 DI Change Detection Applications for more information. Let me know if this helps
Christian A
(2,445 Views)
