How to check if a file exists on RT target
    I wonder is there a way to check if a file on RT target exists? Thanks!
   Tom
(2,933 Views)
Accepted by tom_z
You mean from the host? You could use the FTP functions. "FTP Get Path Info.vi" will return error code 550 if a file does not exist but a success code if it finds it. You can also check the "path info" output. The type will tell you unknown if it doesn't exist but file if it is there.
(2,931 Views)
     It works! Thanks!
    Tom
(2,925 Views)
