How to check the size of a folder in a repository (using an URL not a local path)
Hi I wrote this function to calculate the size of a local folder but somehow I can't make it work for a folder in a repository (using an URL).
Please Help.
Cheers,
~~~ GladiatorLV ~~~
Message 1 of 9
(13,788 Views)
Can you browse to that file through Windows Explorer, or only through a browser?
Cheers
Message 2 of 9
(13,782 Views)
James.Morris I believe I can access it through windows explorer
Cheers,
~~~ GladiatorLV ~~~
Message 3 of 9
(13,764 Views)
Sorry. When I try to open it in Windows Explorer it takes me to a browser
Cheers,
~~~ GladiatorLV ~~~
Message 4 of 9
(13,762 Views)
That's probably the issue, the LabVIEW FIle I/O VIs can work with files that Windows Explorer can work with, but when you go in to the network browser realm, you're unleashing a whole new beast.
Maybe someone else on here has insight in to how to work with files over the internet. (I say internet because it's not just on a drive on the local network, it's at a specific URL)
Cheers
Message 5 of 9
(13,747 Views)
Can you say a bit more about where this directory is, how its configured and what you are trying to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 9
(13,694 Views)
Accepted by GladiatorLV
The repository is online. I wanted to be able to get modified files/folders from one revision to the other, calculate the total size, check if there's enough space on the local disk to export. I completed this using TortoiseSVN commands. svn list -r %s -v %s will give you the size of a file in bytes.
Cheers,
~~~ GladiatorLV ~~~
Message 7 of 9
(13,576 Views)
Very nice.  Where did you find this information?  I've used SubWCRev to get the Revision Number of the current Working Copy, but haven't found any discussion of the commands you describe.  Please share ...
Message 8 of 9
(13,530 Views)
Never mind -- I just "stumbled" over it.  In Windows 7, open a command prompt.  Type "svn help" and you will see that there is, indeed, an "svn" ability that comes with TortoiseSVN and it does contain the List command.  There's even a discussion on the Web here.
Message 9 of 9
(13,525 Views)
