How to check to see if an element is used in a cluster
Ahhhh, I see.
I didn't think of that. I have also used the cluster to xml VI as well.
In the event if a flatten or equalivinet VI is used with the cluser i can still see a benifit of at least brining up a warning (or low risk) that an element is never used elsewhere within a cluster.
Engineering - The art of applied creativity  ~Theo Sutton
Message 11 of 14
(864 Views)
If you ALWAYS use Bundle/Unbundle by Name for your clusters, then a text search for the names will find all the places it is used.  I do not know whether this can be automated.
Lynn
Message 12 of 14
(851 Views)
Lynn
Where there's a will there's a hack way.
Message 13 of 14
(841 Views)
I just cobbled this together.  Try it and see if it works.
Message 14 of 14
(823 Views)
