How to choose the source of sample clock as "analogecomparisonevent"
Hi, everyone. I am a beginner of Labview. Sorry to ask a so stupid question.  When I use the DAQmx Timing.vi as sample clock, I want to choose the terminal "analogecomparisonevent" as the source but I can not find it.  I use the Labview 8.5 and the DAQ card is NI PCI 6115. I add the source terminal of the "sample clock" in this way: right click the vi -- create -- constant.
Thanks very much for your help
(2,947 Views)
Is there someone can help me ? Thanks.
(2,929 Views)
Hellolight,
If you right-click on the constant connected to the source input of your DAQmx Timing.vi, and then click on I/O Name Filtering... , you can check the Include Advanced Terminals option.  You should now see Analog Comparison Event as one of the options.
-Christina
(2,906 Views)
