How to choose which graph will be displayed
I have a chart with 3 push buttons.  All 3 buttons are connected to signal simulators.  The first one is supposed to display a sine graph with an offset of 1, the second is a sine graph with an offset of 3 and the 3rd one is a graph with an offset of 5.  I want to be able to push any button and have the graph appear or disappear.  I could show 0, 1, 2 or all 3 graphs at the same time depending on which buttons are pushed.  Can someone please help me figure out what I'm doing wrong?  I'm a beginner so please be patient if I use the wrong terminology or have trouble keeping up.
Thanks!
Message 1 of 11
(3,898 Views)
Check this . you can hide graph by changing at Graph Legend index check box.
Munna
Message 2 of 11
(3,884 Views)
Hi rhupd,
you need to learn to use basic array functions, simplify your block diagram, remove sequence structures, using graphs instead of charts, so much more…
Message 3 of 11
(3,883 Views)
Hi GerdW,
From what I understand, a graph is used to simply display data whereas a chart stores it.  I want to be able to remember the data being generated so that I can store continuous data for e.g. 2 hours and then be able to access it later.  I also looked at your vi - thank you for the suggestion.  I'm currently studying it and trying to figure out what's happenening.
Message 4 of 11
(3,867 Views)
Hi rhupd,
in your VI you are using shift registers to store data. Why use a chart to do the same again (resulting in double memory allocations)?
Message 5 of 11
(3,857 Views)
Hi GerdW,
I tried running your vi and the second two options don't work.  I used the probe to check and there's no data coming out of the 2nd and 3rd arrays, only the first one.  Why is it doing that?
Thank you.
Message 6 of 11
(3,850 Views)
Hi GerdW,
So if I use a graph with shift registers, I could choose an option and see data.  When I unclick an option, the graph disappears and if I click it again, the signal will appear again with its history i.e. the old data will also be displayed and it won't just start from a new point.  That's a very messy sentence - I hope you can understand what I mean!
Thanks.
Message 7 of 11
(3,846 Views)
Accepted by rhupd
Hi rhupd,
it's because you used the wrong array function and I didn't check all options…
See attachment.
Edit:
You can edit messages. No need to post two messages within minutes…
Message 8 of 11
(3,844 Views)
ignore
Munna
Message 9 of 11
(3,843 Views)
Hi GerdW,
Thank you for your help!  I've been working on this for a week before I finally decided to get help.
Also, how can I edit my message after I post it?
Thanks!
Message 10 of 11
(3,831 Views)
