How to clear the buffer in TCP/IP
Hiii
can any one explain me how to cleat the buffer in TCP/IP communication
(11,941 Views)
Isnt there a function like flush/clean TCP/IP buffer in that palette? I remember something like that...
- Partha ( CLD until Oct 2027 🙂 )
(11,937 Views)
can u send the pallet image ....... actually i donot found such thing...
(11,935 Views)
I use the TCP Read function, with the mode set to Immediate, the bytes to read count set to a large value (say 1M) and the timeout set to 1ms.
I think this always returns a timeout error (or course) so you need to check for this and clean it out.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(11,919 Views)
Hi Karthikey...,
can you explain what you make with it? Why do you need it? Who sends so much data on which you can't work?
Mike
(11,909 Views)
