How to clear the buffer in TCP/IP
Hiii
can any one explain me how to cleat the buffer in TCP/IP communication
(11,933 Views)
Isnt there a function like flush/clean TCP/IP buffer in that palette? I remember something like that...
- Partha ( CLD until Oct 2027 🙂 )
(11,929 Views)
can u send the pallet image ....... actually i donot found such thing...
(11,927 Views)
I use the TCP Read function, with the mode set to Immediate, the bytes to read count set to a large value (say 1M) and the timeout set to 1ms.
I think this always returns a timeout error (or course) so you need to check for this and clean it out.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(11,911 Views)
Accepted by topic author Karthikeyan_Mathiyalagan
Hi Karthikey...,
can you explain what you make with it? Why do you need it? Who sends so much data on which you can't work?
Mike
(11,901 Views)
