11-16-2010 10:00 AM - edited 11-16-2010 10:04 AM
I have a 3-D array of data and I’d like to combine all the pages into one table. Is there a way to do it?
Solved! Go to Solution.
11-16-2010 10:11 AM
Try Reshape Array to take it from a 3-D to a 2-D.
11-16-2010 10:21 AM
Hello Ravens, I've tried it and actually went to 1-D array and the result was mixed... I'm looking to view it in one page with the same format.
Thanks!
11-16-2010 10:29 AM
Did you expand the Reshape Array so you could wire 2 dimensions? By default the Reshape Array has only one dimension.
I don't understand what you mean by "view it one page with the same format". Same format as what? And what do you mean by one page? Can you provide a manual example of what you are trying to accomplish?
11-16-2010 10:47 AM
I want something like this.
Thanks!
11-16-2010 11:15 AM - edited 11-16-2010 11:18 AM
Here is one possibility. Since your 3D array has a variable number of empty rows on each page, a simple reshape alone will not be sufficient, you also need to eliminate empty rows.
I don't know what kind of row order you want, but my solution gives a different order than your desired output. Still, this should get you started. You might need to sort the rows differently.
There could be bugs, so modify as needed.
11-16-2010 11:33 AM
Thanks altenbach!!!
That's exactly what I want...![]()
12-17-2010 12:26 PM
I want something like that.
12-17-2010 07:39 PM
Your math calcualting the indices is wrong.
Here's a corrected version, see if it makes sense.
Also:
12-19-2010 04:40 AM
Thank you so much!
Can you help me to see one more program?
See the program.
If any changes in slider, I want to store 2 values: String value & Slider value inside 2-D Array.
Can event structure handle for 3-D Array?
