How to communicate with SCPI using Labview?
Ok installed both.
Once I open the VI from the block diagram  I go to Instrument I/O >> Instr Drivers >> LCWave (i suppose that are the LeCroy Patterns) is it right?
Instead what I don't see are the patterns for the rigol. I have installed the IVI.exe that I found on the Rigol website properly.
Thank you guys.
Message 11 of 13
(3,973 Views)
@GerdW wrote:
[..] "Saftwares" [..]
Freud'scher Verschreiber, Gerd?
Norbert
Norbert
Expert: Geometry
Message 12 of 13
(3,968 Views)
Hallo Norbert,
nur ein "normaler" Verschreiber, die Bürotemperatur ist schon unter 25°C gesunken... 😄
Message 13 of 13
(3,966 Views)
