How to communicate with SQL using LabVIEW 7.1...?
Hello... 🙂
       I want to create a system which deals with database & stores the database in server through SQL... Can anyone please guide me how to communicate with SQL using LabVIEW 7.1...?
       Thanks for any help from you.. 🙂
Message 1 of 16
(6,097 Views)
Accepted by Rupali
You can either use LabVIEW Database Connectivity Toolkit or LabSQL to communicate with SQL databases. Have a look at those and post back if you have any further questions.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 16
(6,096 Views)
Thanks for reply.. 🙂
Does it mean I have to purchase those software...? Is there any other way...?
Message 3 of 16
(6,089 Views)
The first one YES :), but not the second one. I use LabSQL and it works perfect.
Adnan Zafar
Message 4 of 16
(6,083 Views)
Ok... The condition is same for LabVIEW 8.5 too....? :womansurprised:
Message 5 of 16
(6,080 Views)
It is irrespective of the version.... Smiley Wink
Message 6 of 16
(6,068 Views)
Ok.. Thanks for the help... 🙂
Message 7 of 16
(6,064 Views)
Hello Adnan Z... Can you show me how to use the VI's i downloaded from LabSQL zip file... Means if I have to store some text message in server or I have to read from server how to go for it...?
Message Edited by Rupali on 01-07-2009 01:31 AM
Message 8 of 16
(6,046 Views)
Hi Rupali, I don't understand. You want to execute SQL statements to write something in the database or want to do something else? If it's SQL statements, have you already installed the database and the ODBC driver? When you download LabSQL, it has examples which shows how to communicate with the database.
Adnan Zafar
Message 9 of 16
(6,042 Views)
Ok.... Database means the records which are saved in excel sheet and those should be saved in server.... And one can be able to read or write in that.. 🙂 this is what information I got for my project.. n I have to deal with SQL language.. 🙂
Message 10 of 16
(6,040 Views)
