How to compare different timestamps and check which one is greater.
Hi Guys,
I have a small question regarding datetime.
I have the following data in an array in timestamp format .
01:00:00.000
19-05-2009
01:00:00.000
22-05-2009
01:00:00.000
23-05-2009
What I want to do is to check which date is greater then the other.  Simply my question is how to do comparison between dates , specially when they are in time stamp format
Secondly I would like to ask if I have a timestamp which has the following values
01:00:00.000
22-05-2009
How do i convert it into seconds ?
Thankyou
(10,449 Views)
@OmarTariq wrote:
Hi Guys,
Just use a comparison function directly. The functions are polymorphic. If you don't understand what polymorphism is, then please review the LabVIEW Help and the LabVIEW tutorials, as they cover this behavior.
01:00:00.000
22-05-2009
Just use the Numeric Conversion functions. This will give you the number of seconds number of seconds that have elapsed since 12:00 a.m., Friday, January 1, 1904, Universal Time.
(10,437 Views)
Accepted by OmarTariq
You can build an array of time stamps and use the array min/max to compare sets of timestamps.
Use the to double conversion to get seconds since...
Paul
(10,428 Views)
Oops, missed that we're dealing with more than 2. Yeah, if you've got more than 2 then an array is the way to go.
(10,421 Views)
Great , thats what i wanted.
Would like to thank both of you 😃
Rgs
Omar
(10,417 Views)
