How to concatenate two arrays of strings and obtain a 2 dimension array result.
In the attached vi, there are two examples made with arrays of numbers and strings.
I would like to have the format results for string array as for number array...how can I do it?
I mean a 2d array result as for number example...
array result: first column ad, bd, cd, second ae, be, ce and third one cd, ce, cf.
Thanks in advance.
(2,474 Views)
Accepted by brambo60
I tried to apply the same method used for arrays of number to arrays of string but the result is not the expected one.
I mean: having one array of string "a,b,c" and another "e,f,g" I would like to have, as result of concatenation, a 2d array of strings like:
first column: ad bd cd
2nd column: ae be ce
3rd  column: af  bf  cf
How can I modify the attached vi in order to have the wanted result?
Thanks in advance.
Thanks in advance
(2,421 Views)
Hi brambo60,
Since you want to iterate each element of the first array with each element of the second array, you need two for loops.
Please find attached the VI and reach out as needed.
Fort
(2,446 Views)
Thanks a lot. I forgot to mention also the tentative I have done with two for loops...but  in mine there was a mistake
Thanks a lot.
(2,434 Views)
Duplicate post has now been merged
(2,405 Views)
