How to configure DAQ Assistant with Load Cell
I want to meassure a tension force  in an chain. The motor that drives chain is mounted to an arm. A load cell is mounted between the "free" arm and the machine chassie. The force should then be computed in the labview program...
Hardware:
PCI-6221 DAQ pci-card
SC-2345 box
SCC-SG24
HBM force transducer type U2B
How do I configure the "inputs" using DAQ Assistant?
Should I Meassure voltage or...?
I tried meassure strain in DAQ assistant. But I can't get it to work.
(3,468 Views)
Hello!
I tried to find more information about the transducer you are using without any success:
http://www.hbm.com/products/SEURLF/ASP/SFS/SUBCAT.7/CATEGORY.1/PRODID.269/MM.3,18,23/SFE/ProductData...
General information about strain measurements can be found here:
Strain Gauge Configuration Types
http://zone.ni.com/devzone/conceptd.nsf/webmain/C18F65CE920C115086256D720058325B
Measuring Strain with Strain Gauges
http://zone.ni.com/devzone/conceptd.nsf/webmain/C83E9B93DE714DB08625686600704DB1
The settings you do in DAQ Assistant must match the type of transducer you are using (strain configuration, gage resistance, gage factor and such) and you should find such information in the specifications for your transducer.
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,447 Views)
Thanks!
Very good information.
However I have a problem deciding which one of the three types o Fullbridge to use in Labview.
The sensor is of fullbridge type but doesn't specify any poisson ratio. From what I understand I should use the third type of fullbridge as I want to meassure the axial strain and not the bending strain? Or could the sensor be built as a bending strain sensor, and  therefore I should use fullbridge type 1 and don't have to give any input about poisson ratio?
(3,446 Views)
Hello!
I am not sure at all how the transducer you are using is built up and therefore doesn't know which kind of full bridge you should use. Sorry about that! You might be able to get more information from the company that you bought the transducer from?
Jimmie Adolph
(3,438 Views)
