How to connect Axis IP camera to Ni-Max??
hello,
Thank you very much for reply.
I tried all the settings, but still having the same problem.Smiley Sad
could you tell me that is axis M1031 W camera is supported by Labview or not ?
Because its almost half month i have spent to connect only  camera with labview.
or is there any way in Ni-Vision to control camera directly by giving URL adress or tcp/ip setting.
Please guide me.
thank you very much for your time and help.
Message 11 of 26
(3,265 Views)
Hello AnkitRamani,
National Instruments supports IP cameras manufactured by Basler and Axis, but the NI-IMAQdx driver supports only IP cameras that provide MJPEG images. Axis IP cameras must have firmware version 2.0 (or later) to be supported.
Best Regards,
Cem
Message 12 of 26
(3,235 Views)
My Axis camera is supported MJPEG images, and also I have firmware version 5.20, As in attachment you can see it.
but even though its not open in Ni-IMAQdx, It detects the camera but give me error as I wrote in earlier post.
Thank you very much once again for your time.
Message 13 of 26
(3,229 Views)
Hello AnkitRamani,
I'm afraid, at this time I don't think we can troubleshoot any further. I don't have the option to configure your AXIS - IP cam in MAX, because I don't have it. Could you contact the manufacturer of your camera. Maybe there is somthing you haven't configured yet.
Cem
Message 14 of 26
(3,182 Views)
Thank you very much for your reply.
I have already contact with manufacturer of Axis camera, but form there also they dont have more idea about it.
they told me to do some setting which I have already done, but no result.
any ways...thank you very much for yore time.
Message 15 of 26
(3,174 Views)
When you try to configure your camera using MAX, do you have any other programs open that is connected to the camera ?
From the picture of your error it seems you have the Axis program open.
Try to close all programs that is NOT MAX, and if that helps.
Have you tried to connect to your camera in a vi with the NI-IMAQmx functions ?  Again with any other programs open.
Message 16 of 26
(3,162 Views)
Yes I tried with closing Axis Program, but same error and I tried with by connecting camera directly to the pc even though its not working.
currently I am tring to communicate by D-link Router but its same unknown network error for both cases with router and with out router.
Thank you very much again.
Message 17 of 26
(3,147 Views)
Did you try with a simple vi in LabVIEW ?
Message 18 of 26
(3,142 Views)
simple vi means??
I tried with Axis utility in that axis camera is called directly from local host its working fine.
and any usb camera also work fine with Ni-IMQdx.
Message 19 of 26
(3,135 Views)
Hi dkfire,
I think if you are unable to see the camera output properly in NI MAX, you will not be able to see the camera working in NI-IMAQdx also.
-Please correct me if i am wrong in this (this is so far my observation).
uday
Message 20 of 26
(3,133 Views)
