How to connect incremental encoder to NI9411?
I have to connect an incremental encoder to a NI-9411 digital input module on a cRIO chassis to use for high speed triggering.  I am having some trouble figuring out how to hook the necessary wires from the encoder up to the 9411 correctly.
The wires carry the following signals:
A-Red
B-Green
Z-Brown
+V-Blue
OV-Orange
I'm pretty inexperienced with connecting sensors to LabVIEW gear, so please let me know if I can supply more info about my setup.
Also, attached is the datasheet for the encoder.
Thanks a lot!
Alex
(4,096 Views)
Accepted by byrd
Hi Byrd,
Thanks for the post and I hope your well today.
I am afraid Im not fully sure what your issue is.
The NI 9411 Manuals can be found here:for extra reading.
The operating instructions  covers how to connect Single-ended devices to the 9411.
page 12:
"An example of a single-ended device is a single-ended encoder. Connect each of the signals of the encoder (phase A, phase B, and
index) to one of the pins in a pair of DI pins. Figure 5 shows the connections for one single-ended encoder."
In labVIEW you can then create a DAQmx task to read all the digital lines.
Hope this helps to get you started,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,080 Views)
Thanks for the reply.  Looking at the diagram you noted helped a lot and I got the encoder working!
Thanks again,
Alex
(4,054 Views)
