How to connect phidget current sensor to NI myRIO?
I have a phidget current sensor and NI myRIO equipment, is there any way to connect it?
(3,255 Views)
It looks to me like the sensor gives you an outpur of 0-5V which can be converted in to a current measurement value. You can use your MyRIO to read this analog input value and go from there.
There are plenty of examples for the MyRIO and reading an analog input. There is even an express VI that makes it very easy.
Cheers
(3,241 Views)
I still have trouble doing the programming in labview to read in the values... However, i also wish that the data from labview can be viewed from dashboard.
(3,085 Views)
