LabVIEW 2013 disconnect VI from library
I have read http://digital.ni.com/public.nsf/allkb/CCBEF223C80F3D598625742C006B4F24
but I don't have the option mentioned
I want to disconnect a VI from the library, and I cannot find a way to do it.
Message 1 of 12
(6,821 Views)
You could just delete the VI from the library.
Message 2 of 12
(6,810 Views)
In my experience, that option is only enabled if LabVIEW can't find the library when it is opening the VI.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 12
(6,793 Views)
I tried doing that, but then the VI complains that it needs to be in the library.
Message 4 of 12
(6,774 Views)
Mike...
So, what is the best option of prying a VI away from a lvlib file?
I made a copy of a file1 that is in the lvlib.
I cannot seem to be able to divorce that copy file2 from the lvlib file.
Message 5 of 12
(6,772 Views)
From help:
This VI claims to be part of a library, but that library does not claim to own this VI
If a project library owns a VI, the VI cannot be executed or edited unless that project library is loaded into memory. LabVIEW cannot load the project library that owns this VI.
To correct this error, find and load the project library or select  File» Disconnect from Library on the VI.  Using the Disconnect from Library option breaks the ownership of the VI by the project.  If the project library is password protected, you must provide that password to disconnect the VI from the project library
Message 6 of 12
(6,763 Views)
@RavensFan wrote:
From help:
I loaded the lvlib file. The problem is that I don't see File» Disconnect
Message 7 of 12
(6,753 Views)
Sorry about reviving this last year post, but I started to be annoyed by this kind of "bug"? I do not have the "Disconnect the VI from owning lvlib" option.
Scenario: I want to create another lvlib using some driver VIs coming with a Keithley driver. These VIs are under instr.lib and inside a lvlib. I want to re-use these VIs as starting point for another Keithley device.
As a workaround I can temporary delete the owner lvlib from my computer, and then I get the "Disconnect the VI from owning lvlib" option for the VIs copied physically into my new lvlib folder.
But I do not understand why LabVIEW does not provide me a simple way to do this???
edit: LabVIEW 2015 SP1 32 bit
Message 8 of 12
(6,548 Views)
I definitely see what you mean. The way I deal with it it to use Save As. One of the options is to save a copy that is disconnected from the original library.
Mike...
LabVIEW Champion
Message 9 of 12
(6,542 Views)
Brilliant! 🙂
Thanks!
Message 10 of 12
(6,540 Views)
