How to connect this
Still difference with the one from Multitone vi
Message 11 of 19
(1,084 Views)
Then why don't you simply use the multitone if you can't get your other code to work?
Message 12 of 19
(1,078 Views)
Because i want see a dynamic waveform(waveform will move with time goes by)
Message 13 of 19
(1,068 Views)
is it this what you want?
Message 14 of 19
(1,067 Views)
Thank you man , i have tried this way, but the waveform difference with the one I got from Multitone Generator.vi
I have attached that on the previous page.
Message 15 of 19
(1,062 Views)
I also have tried to compare the waveforms and they are the sameSmiley Surprised. Please look at attached vi.
Message 16 of 19
(1,049 Views)
Thank you , jan barton
I have attached the vi, this function is exactly I want to achieve, but I want use Express vi to achieve, because I want see a Dynamic waveform
Message 17 of 19
(1,044 Views)
Your starement makes no sense. An Epress VI is no more 'dynamic' than this example or the multitone function. In fact, an Express VI is often less 'dynamic'. You just need to place code inside a while loop. Perhaps you should take LabVIEW 101 before posting any more questions.
Message 18 of 19
(1,033 Views)
I don't know why you feel the need to have it as a Dynamic Datatype, but you can use the Express VI  To DDT to convert it.
Message 19 of 19
(1,029 Views)
