I'm using SignalExpress Tektronix Edition to acquire signal from oscilloscope. I use "Tone Extraction" to gain frequency peaks and their frequency values. What I want to do is to continuously record the magnitude of the "detected frequency" in "Tone Extraction", which keeps changing. I searched for such function that can output magnitude value if frequency is inputted, but I didn't find it.
So I'm wondering if this problem could be solved by adding "User-defined Step", say a VI that is programmed to gain the frequecy value and returns magnitude. Hope can get your help. Many thanks!
