LabVIEW & Steppers
Could anyone advise me how I can control a stepper motor using LabVIEW
without using the MotionControl Hardware. Just with the standard LabVIEW.
Regards.
Akram
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
Message 1 of 10
(5,286 Views)
Hi~
i have done that with pulse train under MIO board.
Regards.
In article <7pr6jt$p1v$1@nnrp1.deja.com>,
akram_m@my-deja.com wrote:
> Hi,
> Regards.
> Akram
Message 2 of 10
(5,281 Views)
Hi ......I am trying to control the speed of bipolar stepper motor(STH-56D101) using the Motorola SAA1042 driver and the technique being used is PWM.The VI we are generating is not giving us the PWM wave we need instead its generating a square wave and thus we see no movement in the motor.Plz help me i have been stuck at this point for more than a week .............
Message 3 of 10
(5,112 Views)
Hi sushma,
I tested your code and it seems to work fine.  For the initial cycle, your y value must equal your duty cycle value (0.5).  After the start trigger, you can update your y value as long as your signal has completed one cycle.  You say it is generating a square wave, isn't this correct behavior?  As I update the y value, the duty cycle of the square wave changes.  Can you please give me more information on what you're expecting versus what you're seeing?
Thanks!
Best Regards,
Erik
Message 4 of 10
(5,086 Views)
Duplicate Post, I think he got it working now.
http://forums.ni.com/ni/board/message?board.id=240&message.id=4248#M4248
Message 5 of 10
(5,083 Views)
Okay, thanks!
- Erik
Message 6 of 10
(5,078 Views)
Hi Erik,
Wat is needed is the wave should change duty cycle instead of we changing it and I have no clue how to do that.........
Message 7 of 10
(5,061 Views)
Hi sushma,
I modified your code by generating a sine wave that controls the duty cycle.  The sine wave varies between 0.01 and 0.99.  This is just a demonstration of how you would use a wave to control the duty cycle.
I hope this helps!
Erik
Message 8 of 10
(5,048 Views)
Hi Erik,
I have a 6- wire stepper motor with which I am trying to do the same thing i did with my bipolar 4 wire stepper motor .The specs for this DC synchronous/stepping motor are
type:M062-FD-419 ,
4.2V,
1.9A
Class B INSULATED
 Spec. BM101025 Cont. Duty
200 steps per rev.
Can you please suggest a driver for this motor......?
Message 9 of 10
(4,983 Views)
Hey sushma,
Please repost your question on our Motion Control and Motor Drives board.  They will be much better equipped to answer that question.
Thanks!
Erik
Message 10 of 10
(4,953 Views)
