Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to control DTR (FP-2000) with compatibility serial vi (not VISA)?
Matthew_William
s
Active Participant
11-13-2002
02:49 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I need to directly control DTR on the serial port of an FP-2000, which doesn't support VISA. Any suggestions? Thanks.
Matt
0
Kudos
Message
1
of 2
(2,612 Views)
Reply
Re: How to control DTR (FP-2000) with compatibility serial vi (not VISA)?
JeanPierre
Active Participant
11-15-2002
01:27 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Matt,
The VI located at vi.lib\platform\_sersup.llb\serial line ctrl.vi allows you to set DTR line. The acyual path in vi.lib depends on the version so if it is not there make a search in vi.lib directory for a file named _sersup.llb.
LabVIEW, C'est
La
b
VIE
W
1
Kudo
Message
2
of 2
(2,612 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
