How to control an actuator that do not have an integrated controller?
I am using a PCI 7330 and  UMI-7764 and I would like to know how can I control an actuator that works with 5Vdc using these devices.
I was thinking to use an analogic output, however the PCI that I am using doesn´t have that option..
The version of my Labview is the 8.2 and the NI-Motion is 4.6..
Can someone help me?
Datsheet of the actuator: http://www.firgelli.com/pdf/PQ12_datasheet.pdf
Regards
(2,715 Views)
You want to adapt a linear drive to a stepper controller card....
You will need some driver circuitry that provide the +/- 5V 550mA for the motor, (H-bridge ) add some additional circuitry to build a servo control with an analog input.
Now use one free digital output (inhibit??)  to create a PWM that is followed by low pass (RC) to feed that anaolg input.
If you have three free digital outputs you can bit bang a SPI communication that  controll a DA ....
However you will spend a lot of time for that.... a USB 6009 is cheap ...
Greetings from Germany
Henrik
LV since v3.1
(2,698 Views)
I'll try to get a USB 6009, however this a university project so I do not know if I´ll have money  to buy it...
If not, I´ll try the other solution that you gave me..
Thanks a lot for your time..
Best regards
(2,688 Views)
