Show build status window programmatically
Is there a way to show the build status window progress bar when the application builder is started programmatically via the BuildTargetBuildSpecification.vi? Since it takes quite some time to create a build for our applications (> 1 h) it would be nice to see how much time it is left when a build is started.
I've seen the question posted before about this (http://forums.ni.com/ni/board/message?board.id=170&message.id=204846&query.id=1234930#M204846), but that was some years ago... There are quite many vi's in the AppBuilder directory but most of them are undocumented and not that easy to guess how to use.
/H H
Message 1 of 1
(2,833 Views)
