How to convert array of integer to character String
Hi, I am trying to convert 32 bit Integer array to  character string. For ex: if array contains {1234, 4567, 8, 9} i need string as {00,00, 34,12, 00, 00, 45, 67, ....}
How to do this one.
Please Help 🙂
Thanks & Regards,
Harish. G.
Thanks & Regards,
Harish. G.
(4,652 Views)
Hi Harish,
- Do you need bytes containing your numbers?
- What is the byte order? 1234 should result in 00,00,34,12 and 4567 results in 00,00,45,67???
- What are "characters" by your definition?
Please provide a really good example&explanation of the desired result!
Straight-forward solution by following your descrition word-by-word:
(4,648 Views)
Thank u very much:)
It is a ver good solution for me.
But here you are storing 1234 as 00 00 12 34. In this 00, 00, 12, 34  is two bytes. I need 00, 00, 12, 34 as single bytes.
Thank you for showing a very good example.
Thanks & Regards,
Harish. G.
Thanks & Regards,
Harish. G.
(4,627 Views)
Hi Harish,
your description is still very vague. Do you need commas between those bytes?
Converting the decimal I32 numbers to BCD bytes...
GIVE A GOOD DESCRIPTION OF WHAT YOU REALLY NEED!
(4,623 Views)
Hi, my requirement is
    I have 32 bit integer array, that contains a[] = {11223344, 55667788};
   I need output as follows in 8 bit integer array b[]= {11,22,33,44,55,66,77,88};
Thanks & Regards,
Harish G.
Thanks & Regards,
Harish. G.
(4,611 Views)
Accepted by harishg92
Hi Haris,
use the solution shown above as it seems you really want BCD numbers...
Or this slightly improved version:
(4,607 Views)
       Thank you :).
       This solution solved my problem.
Thanks and Regards,
Harish. G.
Thanks & Regards,
Harish. G.
(4,581 Views)
