How to convert image to JPEG and write to TCP
I need to convert an image to JPEG and write it to a TCP port rather than to a file.
I thought I could modify "Write JPEG File.vi", but it is password protected.
(9,596 Views)
You can save it to a file and then read the file as a string using the file functions.
___________________
Try to take over the world!
(9,585 Views)
The delay is probably small, but I was hoping to avoid that.
(9,577 Views)
Accepted by topic author Rick N.
If you using IMAQ Vision, then you can convert your image to compressed string:
Compressing an IMAQ Image Without Saving to Disk
Also this topic might be interesting for you: Decoding JPEG String
Andrey.
(9,560 Views)
I have not tried this, but you could use ImageMagick from SysExec with the command causing a redirect to stderr, then pull the image as a string from stderr.  There is a host of things that could go wrong, but it is worth a shot.
(9,529 Views)
