How to convert long hex string to individual decimal values..??
Hi Tusharvp,
I would read the data stream and search for the (complete) "start of data" message (hex "FEFC 0101 0101 FD"). Once you found it you know you are in sync with your data stream and now you can parse the next messages (as has been shown by crossrulz).
@Tusharvp4 wrote:
I have a problem only in 0.25 second speed measurement in above VI..
Which baudrate do you use with your device?
Message 21 of 39
(1,076 Views)
My instrument is running on baud-rate 115200...I am receiving whole message without losing any byte on hyper-terminal at 0.25 second...But having issue with last VI..
How to 'start of message'..!! can you please modify in VI...??
However I am receiving 595 bytes in single message..Here I am displaying only 16 parameters..
Message 22 of 39
(1,071 Views)
Hi Tusharvp,
At 115200 baud it takes ~52ms to transfer the whole data of ~600 bytes, so your VI should be able to handle the data.
Read the data, collect it in a shift register. Search for the "start of data" message, as described in your protocol description.
The data behind that "start of data" message can easily be parsed as now you are "in sync" with your data stream.
Because you don't parse the full data set, but only 18 data "subsets"…
Each message "subset" contains the parameter number, so use this to place the decoded value into the corresponding element of an array holding all 82 parameter values!
Message 23 of 39
(1,065 Views)
@Crossrulz and @Gerwd..
Thank you for amazing support...!!
@Gerwd...I did not understand yours last suggestion enough properly...Can you please little help me out through raw arrangement of NEW VI that your are suggesting me..
Message 24 of 39
(1,036 Views)
Hi Tusharvp,
this is showing the concept:
I would probably use a consumer-producer scheme and add more checks to be sure to have the data stream always "in sync"…
Message 25 of 39
(1,025 Views)
How did you write string constant of "FEFC 0101 0101 FD"...??
Message 26 of 39
(1,014 Views)
Right-click on he string constant.  Select Visible Items->Display Style.  You should see a little 'n' appear on the left side of the constant.  Click it and select "Hex Display".  You will now see the bytes in the string in a hexidecimal format.
GCentral
Message 27 of 39
(1,003 Views)
Oh sorry...I was considering x as cross...I thought that it is something new..
Message 28 of 39
(999 Views)
In the past, I ran into major memory issues when trying to parse large strings to handle serial protocols.  So I started reading only what I needed to in order to find the sync byte(s)/frame.  So I would go with something more like this.
GCentral
Message 29 of 39
(991 Views)
@crossrulz
Thank you....!! Sir
I tried yours VI...
But having issue with 0.25 second speed measurement...
Error-1073807253 (Hex 0xBFFF006B) A framing error occurred during transfer...
Message 30 of 39
(981 Views)
