How to copy data of 1D array indicator to the clipboard
Is it possible to copy a data of 1D array indicator to the clipboard, as a text and for more than one cell?
I use LV8.6.
Leszek
Message 1 of 9
(6,289 Views)
You might be out of luck with 8.6, but in newer LabVIEW version you would simply right-click the array and select "export..to clipboard". You can see if you have that option.
Message 2 of 9
(6,284 Views)
As simple as it look. Looks like you already go the answer mr. LeszekB
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 9
(6,278 Views)
@Ranjeet_Singh wrote:
As simple as it look. Looks like you already go the answer mr. @LeszekB
Ranjeet Singh
Knights of NI
Why do you sign with "Knights of NI". What does that even mean?
The title "Knight if NI" has a special meaning here and your signature seem to confuse this.
Please explain what you are trying to say with that signature.
Message 4 of 9
(6,273 Views)
I just copied & pasted.
I dont know what other meaning it having.
Please let me know, if it is something big then i think i should remove it
--Ranjeet
Message 5 of 9
(6,270 Views)
I changed it & no offence but i am not trying to say anyting by that line.
--Ranjeet
Message 6 of 9
(6,265 Views)
I asked about solution in LV8.6.
Message 7 of 9
(6,250 Views)
Accepted by topic author LeszekB
Sorry, I wasn't sure if this was available in 8.6, apparently not.
You could create a small text indicator and use "array to spreadsheet string" to populate it. Now you can simply cut&paste the text instead.
Message 8 of 9
(6,238 Views)
I agree with you. The solution is to convert numeric data to the text.
Thank you very much for a help.
Message 9 of 9
(6,234 Views)
