x axis problem
hallo
i have problem in visualization of recorded data. i have having contineously problem in x axis setting. i have attach heir vi and mention a problem in front panel . your help will be admire and thanking you
BR
kalu
(4,228 Views)
Hi kalu,
maybe you should collect your data in a 2D array instead of using 29 1D-Arrays with their according shift registers?
This will greatly reduce BD size of your VI and so help to understand what's going on...
(4,216 Views)
thanks for reply but i am not able to get solution could you please edit on above vi. please
BR
kalu
(4,207 Views)
Were you trying to paint a work of art?  Nice lines...
But very poor code.  Follow Gerd's suggestion.  We offer help freely on this forum and are not employees of NI.  As such, you will not find anyone who will do the work for you, at least not for free.
Fixing this will be a good learning experience for you.  Most of us went through that.
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
Again... nice painting
(4,197 Views)
@kalu wrote:
thanks for reply but I am not able to get solution could you please edit on above vi. Please
BR
kalu
All I did is remove the duplicated constants(most of them)  Dude! You need to go to school.  Not art school
You may find the style guide a useful resource to improve your code http://www.ni.com/pdf/manuals/321393d.pdf#labview_style_guide
What is that tab doing?  You really only need to check your watch once.  Nice job of re-inventing autoscaling (Just autoscale its only a Right click away)  Other than that... The code smell is pretty bad.  What did you WANT the program to do?
(4,150 Views)
... to display the block diagram  😄
Spoiler
kidding
It might be quicker to rewrite the code from scratch.  It's not that bad, just takes a bit of time.  And a good learning experience to get more familiar with LabVIEW.
(4,129 Views)
You should really consider just crating a 2D array and add data into it using, for example, a for loop.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(4,106 Views)
