How to count area of the signal from the baseline?
Hello!
Please drive me to the function that can count the area above and below from the baseline of my signal.
Like, i have the contineous signal, that has baseline,  and periodic oscillations. I need to count area of the signal tha different from baseline during this oscillations.
Thank you.
(2,656 Views)
hello
u can use the numerical integration vi.
the mode u can choose depends on the accuracy u need.
regards
(2,645 Views)
Assuming you want both the above and below areas to be counted as positive, take the absolute value of your function before integration.
(2,635 Views)
Thank you,
You mean Numeric Integration function? correct.. now im trying to understand what dt is..
(2,621 Views)
