Use a picture as plot-type?
currently I'm working on a special graph. As you know you can change the plot type. For example you can show the curve by showing little squares. Is it possible to show a bitmap instead of the squares or circles or whatever?
I tried to change the Draw XY Data.vi but now I don't know how to do this exactly. I will post a picture of the original and the changes I've already made.
Thank you
(2,823 Views)
Hello gouvi,
sorry but I did not understand what are you going to do. Could you please explain a little bit more your goal? Thanks
Probably it could be helpful if you posted your code.
AmirG
(2,768 Views)
