Static C++ Library in LabVIEW
I want to use the attached library in LV in order to communicate with a device. The library is written in Visual C++ 6 and the developers say that it is compatible with ANSI C projects. I want to use the Call Function Library Node but this can only include dll files. But this library is a static one (lib). The DLL_CHR.def file seems to be a work around so that the library can pretend to be a dll (I'm not really sure about that).
I can open the lib file with node but I can not chose any functions. Can anybody help me?
I'm using LV 7.1 and have the possibilty to upgrade to 8.1 if needed.
Patrick
(3,695 Views)
It may be compatible with ANSI C projects, but then LabVIEW is not an ANSI C project... Smiley Wink
Unfortunately, you need a DLL for Windows. In Linux you use a shared library (.lib).
Can't the developers simply compile it into a DLL? It's not that hard.
(3,686 Views)
Have you looked at using the Code Interface Node? You can access the C++ code through the function generated by LV, and it not necessary that the library be dynamic. Again, making it dynamic is not that hard
(3,674 Views)
I don't have the source code for the library. So I can't create a dll.
And from the manual I've understood, that you need the source code to create CINs. Otherwise it won't work, since you have to declare every methode with the word CIN.
(3,658 Views)
Okay, we can stop the dicussion. I called the support.
Due to complicated pointers and structures the library does not work with LV.
One possibility would be to use LabWindows or low level communication via RS232. Since I only got LV I will do the low level communication.
(3,653 Views)
