How to create a Fuzzy Contoller by using Control Design (CD) icons only
Does anyone knows how to create an effective Fuzzy Control System using only icons from the Control Design (CD)?
(2,963 Views)
That is an interesting question. The Fuzzy Controller is available in the PID Control Toolkit, but it looks like you are trying to obtain the transfer function of the Fuzzy Controller for some specific operating point. Is it correct? Well, to do that you would need to obtain the specific operating point and do numerical linearization around this point, since Fuzzy is inherent Non-linear.
On the other hand, it is the first time I see this request. Could you provide more information to what you are trying to do?
Thanks!
Barp - Control, Simulation, RTT and HIL - National Instruments
(2,926 Views)
I am required to use a Fuzzy Controller to control an output step response and the problem faced while using Control Design icons is that these icons do not include 'summation', unlike Simulation which has 1 'summation' icon. Simulation is also quite bothersome to a certain extent, whereas Control Design (CD) is much simple to use. As PID can be used in Control Design, I would also like to be able to switch my PID controller in the Control Design to a Fuzzy controller easily, thus I hope to find a way for fuzzy logic icons to be utilised well in Control Design.
(2,905 Views)
