VI reboots PC while executing DLL with non standard pointer assignment
Hello NI developers!
In my DLL there is a following code block:
for (i = 0; i < 10; i++)
                                 if (fIsRead)
                                        ((UINT32 *)(pDma->pBuf))[i] = i;
                                 else
                                        ((UINT32 *)(pDma->pBuf))[i] = 0xdeadbeaf;          /* to be overwritten by WRITE dma */
Which causes reboot of PC.
By thinking that I haven't allocated memory for this array - I even substituted this loop by this string:
((UINT32 *)(pDma->pBuf))[0] = 0;
The same result - PC reboots.
Could you explain possible reasons why this might happen ?
Best Regards,
ACiDuser
(3,247 Views)
Hi there
please post the complete C-Code, especially the variable declarations.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,244 Views)
The code block, where PC reboots is highlighted by comment " /****** THIS STRING, where PC REBOOTS ******/  "
Code is attached below.
Thanks in advance.
(3,230 Views)
Sorry, i can't find the definition of PDIAG_DMA.
How to you allocate the memory for PDIAG_DMA pDma in MenuDMAOpen ?
Best regards
chris
(3,226 Views)
PDIAG_DMA is defined in test.h
//============= test.h ===============
typedef struct {
    VIRTEX5_DMA_HANDLE hDma;
    PVOID pBuf;
} DIAG_DMA, *PDIAG_DMA;
pDma defined in virtex5_lib.h
//=========== virtex5_lib.h ====================
 typedef struct {
    WD_DMA *pDma;
    WDC_DEVICE_HANDLE hDev;
} VIRTEX5_DMA_STRUCT, *VIRTEX5_DMA_HANDLE;
as I understand memory allocates in one of the source files (wdc_dma.c)
//====================== wdc_dma.c =============================
static DWORD DMABufLock(PWDC_DEVICE pDev, PVOID *ppBuf,
    DWORD dwOptions, DWORD dwDMABufSize, WD_DMA **ppDma)
    DWORD dwStatus;
    WD_DMA *pDma;
    DWORD dwPagesNeeded = 0, dwAllocSize;
    BOOL fSG;
    if (!WdcIsValidPtr(ppDma, "NULL address of DMA struct pointer") ||
        !WdcIsValidPtr(ppBuf, "NULL address of DMA buffer pointer"))
        return WD_INVALID_PARAMETER;
    fSG = !(dwOptions & DMA_KERNEL_BUFFER_ALLOC);
    dwAllocSize = sizeof(WD_DMA);
    if (fSG)
         * Since the first and last page do not necessarily start (or end) on a
         * PAGE_SIZE boundary, add 1 page to support the worst case scenario
        dwPagesNeeded = ((dwDMABufSize + GetPageSize() - 1)/GetPageSize()) + 1;
        if (WD_DMA_PAGES < dwPagesNeeded)
            dwAllocSize += ((DWORD)sizeof(WD_DMA_PAGE) * (dwPagesNeeded -
                WD_DMA_PAGES));
            dwOptions |= DMA_LARGE_BUFFER;
    pDma = (WD_DMA*)malloc(dwAllocSize);
    if (!pDma)
        WdcSetLastErrStr("Failed allocating memory for a DMA struct\n");
        return WD_INSUFFICIENT_RESOURCES;
    memset(pDma, 0, dwAllocSize);
    pDma->dwBytes = dwDMABufSize;
    pDma->dwOptions = dwOptions;
    pDma->hCard = pDev ? WDC_GET_CARD_HANDLE(pDev) : 0;
    if (fSG)
        pDma->pUserAddr = *ppBuf;
        if (dwOptions & DMA_LARGE_BUFFER)
            pDma->dwPages = dwPagesNeeded;
    dwStatus = WD_DMALock(WDC_GetWDHandle(), pDma);
    if (WD_STATUS_SUCCESS != dwStatus)
        free(pDma);
        WdcSetLastErrStr("Error 0x%lx - %s\n", dwStatus, Stat2Str(dwStatus));
        return dwStatus;
    /* If a contiguous kernel buffer was locked, update buffer */
    if (!fSG)
        *ppBuf = pDma->pUserAddr;
    *ppDma = pDma;
    return WD_STATUS_SUCCESS;
(3,211 Views)
