How to create a working link anchor in an EXCEL document with the report generation toolkit?
I am using the latest report generation toolkit and want to add links on the first worksheet pointing to the other worksheets in the same document.
I am using the "Append Hypertext Link Anchor to Report" VI. The links are created, but don't work when clicking them.
Question now is: How does a link to a cell on a different worksheet needs to look like?
It can not be that complicated but all variations I tried did not work and I could not find any information about this problem. So any help is appreciated!
Thanks and Regards,
Ingo
(5,875 Views)
Accepted by IngoB
You have to go down to NI_ReportGenerationToolkit.lvib:Excel_Insert_Link.vi On the Hyperlinks invoke node you will need to wire the subaddress node to the cell location you want to link to.
Brian
(5,871 Views)
Thanks, Brian, for your support! - It's working.
It's hard to understand why NI did not pass this parameter to the top of the call chain...
I also needed some time to understand the syntax of the string passed to the subaddress node:
The name of the worksheet needs to be framed by single quotation marks and the following cell address must preceeded by an exclamation point (!).
A working link pointing to cell "A1" of "Worksheet 1" looks like:
'Worksheet 1'!A1
Maybe also of interest: If you want to point the link to a worksheet inside the document itself, the parameter "address" (URL of link - href) can be left empty.
Thanks and Regards,
Ingo
(5,835 Views)
