06-29-2006 10:14 PM
06-29-2006 10:16 PM
Follow these steps to create an icon on the desktop which, when clicked, runs a VI:
1. Put the VI on your desktop.
Hope this helps,
-D
06-29-2006 10:25 PM
06-30-2006 01:16 AM
Open the VI.
Go to File>>VI Properties>>Execution and check Run When Opened.
Note that if you close the VI when you stop it, then you will have to place it inside another VI in order to edit it.
Another option for all this, of course, is to build an executable of this VI (if you have the application builder installed). You should be able to do this from Tools>>Build Application...
06-30-2006 01:52 AM
