How to create custom error based on timeout scenario
I have an array of 10 switches that I send a command out to via digital output module NI9477, then I want to read if those output commands triggered a response with the LEDs that are controlled by those 10 switches within a pre-specified number of seconds. How can I throw an error or warning if the LEDs don't change state within the time limit?
Example:
command: turn on LED 2 and LED 4. turn off LED 5. timeout limit: 5 seconds
Remaining LEDs 1, 3, 6, 7, 8, 9 are not affected.
sent to digital output
reading digital input module NI9425
LED 2, 4 and 5 indication on front panel does not change state within 5 seconds.
How can I create a pop up message that says "LED X did not turn on within X seconds" ?
I've attached an example VI (with unconfigured/non functional DAQ assistants) that captures the essence of what I'm trying to accomplish. Due to the nature of my actual project, I cannot post the vi. I also don't have NIMAX installed on the machine I'm currently on.
*To be clear, my intent is how to generate error (not just display). How to time how long the input takes to respond to the command.
(3,557 Views)
Accepted by sam18
Look under the Dialog and User Interface palette and you'll see 1, 2, and 3 button dialogs there.
(3,539 Views)
How do I trigger the error though? I currently have a block that uses a selector if the input time exceeds the timeout value. But how do I measure the time in between the LED circuit receiving the command to the LED and when the LED actually changes state?
(3,503 Views)
You program it that way!
Are you familiar with shift registers?  Are you familiar with comparison statements and case structures?
If the answer is no, then I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
Write down a simple flow chart or some pseudo code that defines the logic you want, then you can search the palettes for the functions you will use to implement your logic.
(3,469 Views)
