How to create "pick only one" controller?
Hi ..i am new here..
i want to create a control panel with the following functions.
- control panel consist of 5 elements inside
- if i choose LED 2, will perform [action 2]
- if i choose LED 4, will perform [action 4]
and etc...
now my problem is.. when i click LED 2, it does perform [action 2]
but when i click LED 4 in sequence, LED 2 light is still on.
( The concept i want is ...when i click LED 4 in sequence, LED 2 will auto turn off, LED 4 will turn on)
i want to make it only ONE option can be chosen during the operation.
any idea?
Message 1 of 9
(3,657 Views)
It's should be very simple.
Just wire FALSE constant to rest of the LEDs & TRUE to the one selected.
Once you get which LED got selected, you can easily do this.
It will be good if you post ur VI to understand the logic.
I hope this helps. Kudoes are welcomed.
Message 2 of 9
(3,644 Views)
Hi kekin,
i don't quite understand it.
my LED array is control, how can i wire true/false to them?
Sorry i can't post the Vi here as i hav no idea how to build it
An array of 5 LED as control
criteria : only can choose 1 at a time
             if i choose LED 1, perform [action 1]
             then if i choose LED 2, LED 1 must off, perform [action 2]
I wonder does labVIEW provide any control with such functions?
Message 3 of 9
(3,642 Views)
Accepted by topic author sharinganez
Yes there is a control called RADIO buttons. suits your application dear.
Message 4 of 9
(3,635 Views)
If you don't want to use radio buttons, then use an event structure.  Inside the event case, replace all the other elements of the array with a False.
An XOR function will work nicely.
Message 5 of 9
(3,632 Views)
Oh its so easy!
Thanks dear Robot tongue
Message 6 of 9
(3,631 Views)
Hi Ravens Fan,
Thanks for your solution as well.
Btw, what is the thing that connect to the output of XOR gate?
im trying now
Message 7 of 9
(3,619 Views)
Its the LOCAL variable of ARRAY control. You can create it by Right clicking on Array control.
Message 8 of 9
(3,613 Views)
oo..cant recognise it as symbol not quite same
im using 8.5
Thanks kekin n ravenFan
both solutions work as well
Smiley Happy
Message 9 of 9
(3,610 Views)
