Need help to pass VISA references to external code module
I have a dll which use to access gpio through com port but it need to create handler to access it.
So, how am i going to convert the Visa resources name to valid ID handler??
I have go through the KB : Can I Share Open VISA Sessions in LabVIEW with External Code?
Inside get mentioned:
However, the Call Library Function Node can perform this conversion. If you wire a VISA resource name or VISA refnum to a 32-bit integer input terminal of a Call Library Function Node, the node coerces the refnum into a valid VISession ID, which you can use in your external code.
How can i do this??
Thanks and Regards,
Simon
Message 1 of 9
(4,352 Views)
hi simon76,
  what exactly you want to do?Whether you want to convert a refnum to I32 or you have any problems with call library function?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 9
(4,342 Views)
try refnum to session
Message 3 of 9
(4,324 Views)
Let me explain the details: i need to access a hardware by usb-uart, after driver installation, it works like normal com, i have no problem to read/write. Now, i will control the gpio & been given dll, and i try on vb by create handler
hDrv = CreateFile(TEXT("COM1"), GENERIC_READ | GENERIC_WRITE, 0, NULL, OPEN_EXISTING, FILE_FLAG_OVERLAPPED, NULL);
 and is working fine.
Since labview return back visa resource name, so how can i convert to handle ID session to be use on external code module??
KateB,
where can i get the refnum to session property?
Message 4 of 9
(4,308 Views)
Use search in function palette, and search with the same function name.
Message 5 of 9
(4,302 Views)
Do you mean search for visa in function paletta??
thanks and regards,
Message 6 of 9
(4,295 Views)
Search for "refnum to session" in function palette.
Message 7 of 9
(4,293 Views)
What version of LabVIEW are you using?  I don't see that in LV 2010.
Message 8 of 9
(4,287 Views)
Ok. That one comes with TestStand. So try http://digital.ni.com/public.nsf/allkb/FB001AA027C8998386256AAD006C142D
Message 9 of 9
(4,281 Views)
