How to create "type Specifier VI refnum" as shown in the NI example below? See attached VI.
I would like to create a create VI that will be calling 2 other VIs. I found this NI example, picture below that shows how to call another VI, but I don't know how "type specifier VI refnum" was created.
Can someone please help?
NI Example:
My struggle:
(1,080 Views)
As always, just right-click the connector and "Create constant".
Then right-click the constant and select VI server class...browse, and select a Vi that has the desired connector pane.
(1,064 Views)
I think I  figured out how to do it, but now my code does not work. My goal is to call two VIs when I run the CallerVI.vi
(1,061 Views)
@GRCK5000 wrote:
..., but now my code does not work.
You need to be more specific.
(1,058 Views)
Accepted by GRCK5000
To call two VIs you would just place them on the diagram of the caller right? Why are you jumping through all these flaming hoops?
(1,056 Views)
Thank you, Mr. Altenbach! I did not need these loops. I figured it out.
(1,033 Views)
