How to deactivate timeout of instrument assistant
I dont want the instrument assistant to time out if there is no serial input.  :smileyvery-happy:
The only way i know how to do this is open front panel of the instrument assistant and  delete the timeout number constant block from the property node's timeout setting.
But i dont really like to blow up the instrument assistant, is there a simpler way to do this? Like deactivating some setting? :smileysurprised:
Thanks you.
(2,834 Views)
Accepted by topic author sunflower2772
Within the I/O assistant, you could set the timeout to -1 which will actually become 4294967295 milliseconds (the maximum value for a U32).  That would be a timeout value of nearly 50 days.
But why would you want that?  I see no logical reason not to have a reasonable timeout value.  A timeout is intended to protect you from trying to read a message that never comes.  Suppose a cable gets kicked out before the response to a message comes back.  Do you want your code to freeze forever waiting for a response that will never come?  Or would you like to detect a timeout error and handle that gracefully.
(2,831 Views)
