how do i modify which plots appear in a chart?
Hello Users,
I have 8 AI channels  that I am receiving data on.  I am taking 1 second averages of this data and then plotting these averages on a chart.  However, I would like to be able to choose which datasets I view on the chart at one particular time?  In other words I want to be able to deselect some datasets, but keep them in memory, so that I can add them back to the chart at a later time.  Is this possible?
Pat
(2,860 Views)
Hopes this helps.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(2,850 Views)
Thanks for the help.  THe only issue is that I need to apply this to a chart and not a graph.  Do you think it will still work?
(2,811 Views)
Ya it works for waveform chart also. did u tried?, I thought it will good practice to u to change for waveform char. No probs find the VI for waveform chart.
Balaji PK (CLA)
(2,796 Views)
