How to deal with the C++ Callback function in Labview
I am tring to get the image data from a Video Capture card. The SDK is a DLL and an .h file. I met some problems when I am using the Call Library Function Node for a function. The function was described like this:
Function Name: int RegisterStreamDirectReadCallback(STREAM_DIRECT_READ_CALLBACK StreamDirectReadCallback, void* Context)
Parameter: STREAM_DIRECT_READ_CALLBACK StreamDirectReadCallback
                  void* Context
Callback function explanation:
typedef int (* STREAM_DIRECT_READ_CALLBACK)(ULONG channelNumber, void * DataBuf,DWORD Length, int FrameType,void *context);
 ULONG channelNumber               channel number
 void* DataBuf                                  buffer address
 DWORD Length                              buffer length
 int FrameType                                 buffer type
 void* context                                   device context
so how can I define the parameters in the Call Labrary Function Node for this ?
(4,320 Views)
Hi Roger,
I'd recommend taking a look at this community example, Calling C/++ DLLs Containing Simple and Complex Data Types from LabVIEW
I'm most concerned about the DWORD data type--what errors does it throw when you try to get the DLL to work with it or what performance are you seeing?
Marti C
NI Medical
(4,294 Views)
This is a commonly-asked question, and the recommended approach is to write a small DLL in C with the callback, and use that callback to trigger an event in LabVIEW.  There are many posts in this forum on this topic; try a search for "callback dll."
(4,285 Views)
